New 3.73's Now It "WHINES" HELP PLEASE???
Hey Guys,
I just put in 3.73's in my stock rear end10 bolt. Then ever since it whines. I installed the complete instulation kit. All new ring, pinion, races, bearings, bolts seals shimes the whole 9 yards. I went 65 miles and still the noise. I know it says the break in period is 220 miles or so but what could be wrong. It was a jegs gears with richmond instulation kit. Please help this is my DD any the noise is kinda loud.
Thanks
Thanks
gears are set up wrong, what did your pattern look like when you installed them??
what are your install specs, pinion shim, pinion pre-load, carrier bearing pre-load, ring gear back lash??
the main things in any ring and pinion job are:
pinion depth, pinion bearing pre-load(always use a new crush washer), carrier bearing pre-load, and back lash, do all this then check your pattern if it is good you should be fine as with no gear whine,, if the pattern is not good take it apart and make the changes to your pinion depth (re-set backlash) and yes another new crush washer
or you can leave the crush washer and pinion seal out till you get it all set up, then take it apart and use the crush washer and pinion seal on the final assembly
The pre load was supposed to be at 25-30 inch pounds and we set it at 30 inch pounds.
The back lash could be .008-.010 and it was set at .009
We had left the pattern the same
Then we reused the axles bearings, the axles, and carrier with the spyder gears.
what does "we left the pattern the same" mean,,, when you used the gear marking compound and ran the pattern was it good or bad??
I figured it out it was the spacers on the pinion they weren't set right on the ring. So we had to add more but we are doing it tommarrow because we need to order a new crush collar. Im 90% shure thats what it is. Let me know what u think.
Thanks
Thanks
