ptp vs motive?
Old Apr 30, 2007 | 05:18 PM
aNuBiS's Avatar
Default ptp vs motive?
Is Power Transfer Parts (ptpgears) the same company as Motive, if so is it the lower end or higher end or if not are they worse or better than motive?
Any input is good, thanks
Old Apr 30, 2007 | 07:50 PM
aNuBiS's Avatar
bump plz
Old Apr 30, 2007 | 08:58 PM
jakes4321's Avatar
Just use the Motive Gear Performance line.We use them in our shop and havent any problems since they went with the Italy gears.
Old Apr 30, 2007 | 09:00 PM
mzoomora's Avatar
14 Second Truck Club
It is probably somebodys private label.
aNuBiS's Avatar
so then motive and PTP arent the same?
So if I bought some motive performance gears, and was shipped a set of PTP gears, should I be upset???
Old May 1, 2007 | 11:35 AM
aNuBiS's Avatar
bump for help
Old May 1, 2007 | 07:57 PM
mzoomora's Avatar
I have never even heard of PTP. It is probably somebodies private label brand, where are you buying them from? Who knows who actually makes them, probably an overseas manufacturer and they have them boxed with their own name. They could be almost anyones, you would need to look at the markings on them to see.
Old May 1, 2007 | 08:29 PM
aNuBiS's Avatar
I just checked online, they are Richmonds lower end gear.
Would that make them any better or worse than Motive Performance gears?
www.ptpgears.com
Old May 2, 2007 | 12:04 PM
aNuBiS's Avatar
bump for that question
Old May 2, 2007 | 12:33 PM
cowboysfan's Avatar
what does "ptp" stand for?
I saw Richmondslower gear but, does that mean somebody else (company) is making it for Richmonds and Richmondsis approving them/It?
Old May 2, 2007 | 12:36 PM
aNuBiS's Avatar
power transfer parts
Old May 2, 2007 | 10:35 PM
mzoomora's Avatar
If you read that page no where does it say that they are manufactured by them or in the US, just that it is a line of gears from them. That would lead me to believe that they are imported since MADE IN THE USA is a good selling point. I would say they are probably equivilent to the mid or low end Motive Gear stuff (the blue box is mid range, and they also sell some white box stuff for people to private label). Without knowing where they are produced and who the plant is it is hard to say.
Old May 3, 2007 | 08:23 AM
aNuBiS's Avatar
Definitely not on par with a Motive "Performance" gear set?
Old May 4, 2007 | 08:38 AM
aNuBiS's Avatar
bump...
Old May 4, 2007 | 08:54 AM
JS's Avatar
JS
Wrong,I sell them and they are fine...
They are white boxed richmonds no label,they are NOT lower end richmonds..
Old May 4, 2007 | 09:36 AM
aNuBiS's Avatar
Awesome, good to know. Thanks for chimming in and clearing this up.
