What fluid on a moser 9 inch?
Old May 18, 2007 | 04:34 PM
eliteweiner's Avatar
Default What fluid on a moser 9 inch?
I'm sure this has been asked before, but what does moser reccomend fluid wise for the rear-end?
Old May 18, 2007 | 04:53 PM
WFOSS's Avatar
When we installed my bros. 9 in. from Moser, the instructions said to use regular (non-synthetic) 80w-90 gear oil and add the posi-traction additive. Personally, i like Valvoline, but whatever brand you prefer should be fine. Hope this helps.
Old May 18, 2007 | 06:09 PM
EPP's Avatar
EPP
80w-90 gear lube, non synthetic is correct. If it is a Truetrac, you do not need to use any additive. Bob
