View Poll Results: Which Gear is the Quitest?
Motive 3.73
22
26.83%
GM 3.73
55
67.07%
Richmond 3.73
5
6.10%
Voters: 82. You may not vote on this poll
Which Gear is Quiter??
Old Jan 3, 2008 | 12:06 AM
LS1_K1DD's Avatar
Originally Posted by BlackScreaminMachine
Ived delt with Richmonds, they are god awful noisey.
X2. Long drives were a bitch!
Old Jan 10, 2008 | 09:44 PM
BirdofPreyBandit's Avatar
Originally Posted by 5_02ls1
ive said this to people too many times ....the brand of gear has nothing to do with noise...its the tech installin the gear....
if yourgears are noisy somthing is off....usually loose clearances or
not enough bearing preload...unless a gear is straight cut it is not supposed to make noise....
I have a Moser 12-Bolt with 4.11's that whine like a Coyote. The entire rearend was assembled by Moser and I had a local "gear guru" take off the cover and check out all the specs. Everything looked great. After about 5 passes at the track, they started whining. I don't think even the best mechanic in the world would've been able to install these gears and not have them whine.
Originally Posted by axisT6
Yesterday I installed a set of MOTIVE 4.10 gears for a guy on performancetrucks, and with the windows up, AC off, and radio off, there was NO noise.
When I had 4.10's installed on my stock 10-bolt, they didn't whine at all. It took a few hard launches at the track then they started making noise. Sometimes it takes a couple of passes to wake them up.
Old Jan 14, 2008 | 10:15 PM
BlackZ28629's Avatar
Originally Posted by donkey mule
It is also the nickel content in the Richmonds which make them louder.
its the way the teeth are cut.... and they aren't that noisy...mine aren't and Im still in break in...they are the strongest though..
Old Jan 18, 2008 | 03:48 PM
Midnight02's Avatar
I have Motive 3.90's....they don't howl like my buddy's Richmond's do, however I do have a little whine at around 70 mph. The whine is bad enough that the girlfriend and I don't take the SS on long trips anymore. If it's just me in the car, I really don't care that much because with the radio blaring and the cutout open, a little gear whine is my last concern.
Old Aug 31, 2008 | 11:10 AM
wht01ws6ta's Avatar
Who was the one dude who voted Richmond?
Old Aug 31, 2008 | 05:17 PM
bcgetfresh's Avatar
lmao!! x2
Old Sep 26, 2008 | 10:40 PM
DeepV's Avatar
My richmonds are loud, and the rear has been lashed two times, and is at spec. I also have 35 spline axles, that could be adding to it.
*edit*
BTW, i have 4.10's
Old Sep 27, 2008 | 06:37 AM
Black 99 Bird's Avatar
My GM 3.73s were as quiet as my factory installed 3.42s.
Old Sep 27, 2008 | 09:08 AM
Grn4fbody's Avatar
Motives were LOUD in my 9inch, I went with Yukon's
Old Sep 27, 2008 | 04:34 PM
DSkyles's Avatar
Richmonds are quiet if you find someone who knows what they are doing to install them. I have richmond 3.73's in my camaro and had them put in by a guy that has been doing rear ends for over 20 years. They don't whine. Period.
Old Sep 28, 2008 | 11:13 AM
ZeeTwentyFate's Avatar
ive NEVER had a set that was quoet in my 10 bolt, my 12 bolt was BAD from moser, got a guy to setup a richmond gear set, then i hated them so i put some US gears from Moser and set them up and were quiet as a mouse... then the posi broke. ordered a 9in and did the 2 minute break in and 10 minute drive and cool like Moser recomended ... one hard launch and rowing through gears with the Mcleod and bam gear whine...bad... AGAIN!
Old Sep 28, 2008 | 12:13 PM
  #32
MY99TAWS6's Avatar
I had 4.10 gm motives in my 97 ta. Quiet super quiet. Then put them in my 99 ta.Horrible whining. Not sure what was up. Checked and rechecked. Put in richmond 3.73 after that. Even more horrible than the 4.10s. They say they are stronger but guy that got them off me put them in his wifes paxon lt1 and they didn't make even one pass at the quarter on et streets.Richmond suck!
I went back to factory 3.42 and very quiet again. I am going to strange rear end dana 60 and see how that goes.if they are noise they go to like factory dana 60 gears should be able to get them quiet if do that.
Best bet is actual gm gears. Pricey but should be very quiet. These rear ends are crap though and more you track them likely the noisier they are going to get no matter who sets them up.
Old Oct 7, 2008 | 04:10 PM
  #33
rel3rd's Avatar
FWIW, I just put some Summit brand 410's ($150) in my 10 bolt this past weekend. Since it is/was an experiment with a 2 series carrier in my car, I didn't want to spend anymore cash than need be.
I was surprised at how easy they were to setup, and they are as quiet as stock.
Old Nov 11, 2008 | 09:28 PM
  #34
DaddySS's Avatar
AAMs are more forgiving of set up than the others - very quiet.
Old Nov 14, 2008 | 11:10 PM
  #35
cherryelky305's Avatar
I have richmond 3.73's in my el camino 10 bolt, they never made a noise, even after i completely rebuilt the rearend. Ive never been in a car that you could hear the rear in, is there a video or sound clip somewhere that i can hear what "noisy gears" are?
Old Nov 14, 2008 | 11:59 PM
  #36
sixpack_2_go's Avatar
i had Strange 4.10 ring and pinion and it never made a peep. strange or (u.s. gear) is very quiet
Old Nov 15, 2008 | 12:52 PM
  #37
devinfbody's Avatar
My richmonds were loud from day 1. Only at hiway speeds and when coming to a stop. I will probably go with motives and a 12 bolt when i explode them.
