12 bolt rear swap(NEED HELP)
Justin Reynolds
Plus, if it's out of a '77 truck it could probably use a rebuild anyways.
The worse problem is the truck 12 bolt is a wider track vehicle than a F-body. You would need to shorten the axles & axle tubes. That right there takes the cheaper cost intially & tosses it out the window. Not to mention if you want to retain ABS, & the OE style disc brake set up. Each of those would require modifications.
There is more here than meets the eye.
