how to paint the rearend??
I just want some flat black or something low visibility.
Thanks.
If its a new rear like a moser, sand paper to get any surface rust off, and get the surface prepped and its pretty much the same proceedure as before.
After applying two coats to the rear, plus painting my front spindles and both sway bars, I still have more than a pint left over! Stuff works waaaaaaaaaaay better than Rustolem or other typical metal paints.
Otherwise, I've also had good luck with rattle-cans...the VHT engine paint has worked well for me.
