Those with t56 and 4.10...
Thanks,
Derek
but since he has a cam in it it can rev higher anyway so he should not have a problem. So 5th is not an option.
In 4th with 3.42's I go through the traps at approx 5000 rpm so even a stock car can benifit from 4.10's.
The rev limiter should be at least 6500 due to the cam and better valvetrain and that gives you more room for increased MPH.
Here you go check for yourself. Input all info including tire size and rev limit and see what he will be going through the traps at.
There is not reason he would have to shift to 5th with those mods/gears unless he traps higher than 112mph (with a stock rev limit 6K) and 121mph at 6500rpm.
Chances are if he just did a z06 cam, he's probably revving to 6500. Theres no way he's trapping 121 though so he'll be fine. If anything, non perfect driving will lower his MPH
