Broken Axle?
Old Jun 4, 2007 | 06:12 PM
1998LS1SS's Avatar
Default Broken Axle?
For some odd reason one day i started hearing my rear end pop when i would make sharp turns...kept on getting worse and worse untill i decided to check the fluid and it seems like my passenger side axel lost some teeth and there was alot of metal shavings...im a complete noob at this so do i need a whole new rear end...is it an easy fix? i wasn't able to take some pics...if i drive it would i mess up the whole rear end? Any help would be appreciated...thanks.
Old Jun 4, 2007 | 06:20 PM
billybadd's Avatar
When mine was popping on turns i had a bad torsen. Not sure if thats the case for yours.
Old Jun 11, 2007 | 09:21 AM
1998LS1SS's Avatar
Nope, it was a broken posi unit!!! new rear end in already.
Old Jun 11, 2007 | 02:59 PM
white99's Avatar
I just broke my rear end for the 2nd time within 2 weeks. My carrier teeth were all grinded from a hard 4.5k drop. It drove fine in a straight line but any slight turn it would grind. time for a new posi and 373s
