narrowed rear question...
Old Oct 26, 2002 | 12:06 AM
Slow Z28's Avatar
Default narrowed rear question...
just wondering how far you can go narrowing on each side before affecting the suspension mounting points. i like the look of a shallow offset rim on the rear(3.5" bs compared to out 7.5" on our 15x10 rims for example). i don't know if i could go THAT much, but that doesn't bother me. just wondering so i can get some weld drag magnum 2.0 rims or alumapros. any thoughts on the narrowing? anyone do it? this would be for an aftermarket 12 bolt or 9inch
Chris
Old Oct 26, 2002 | 01:29 AM
JimmyKash's Avatar
Default Re: narrowed rear question...
from a stock 4th gen width....probably a maximum of 2" to about almost 3"...but i'm not sure on the 3" per side.
My friend has a 12 bolt on his thirdgen and shortened his rear 15/16" of an inch to make it line up pefectly with the lip of the wheelwell and it looks really nice but even thought he ordered it that way from KTRE, he still had to grind off and re-weld a lot of his brackets
So to alleviate this problem for me, i'm just going to order a bare rearend with no brackets on it with the width i want and grind off and weld on all my brackets. It might take more time that way, but i probably would end up modifying it anyway *shrug*
There is a place in iowa that will sell you a 9" housing any width you want with moser axles, retainers and studs for $550. Buy a torque arm mount from Currie enterprises for $150 and re-use brackets from a junk rearend. As long as you can weld...you could come away with a 9" rear end for pretty cheap.
Figure $700 plus shipping and then minus what you get for a stock rearend and then plus a thirdmember.
<img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
