Driveshaft weights?
Old Jun 16, 2007 | 11:12 AM
UCABlackChevy's Avatar
Default Driveshaft weights?
I would use the search like I always do but the search is bunk and I couldn't find anything on the google search so here it goes.
I am having an odd vibration in my car. Under medium acceleration in any gear around 2000 rpm I am getting a shuddering. I got under the car to check the driveshaft and ujoints.
Driveshaft: I got under there and looked at the driveshaft it looked fairly straight but I see only one weight. Everywhere I have read says something about weight(S) and speaking of driveshaft weights in plural form as if there are multiples. My question is am I supposed to have more than one driveshaft weight on it?
U-joint: I was told to look for a worn ujoint, problem is I don't know what a worn ujoint looks like. I put the car in neutral and pulled the e-brake and tried rotating the driveshaft. I had some movement in it, I would say between 1/4 and 1/2 inch.
Any help is greatly appreciated.
Old Jun 16, 2007 | 01:01 PM
WS6WRX's Avatar
The number of counter wieghts on the stock drive shaft can vary. As for the movement, there should be zero play/movement in the actual ujoints. Double check but I assume that the play you noticed was in the trans/rear end. The vibration is possibly from several factors, try flipping the driveshaft 180 deg on the rear end flange. Other causes are worn pinon/ring gear, bent/twisted axle, wheel bearings, axle bearings etc...
