Part numbers for 4.33 gears for 12 bolt?
Hi guys, Anyone have a summit/jegs part number for 4.30/4.33 gears for a 12 bolt?
Are there differences between Moser and Strange 12 bolt housings? ie: do they use the same gearsets?
thanks,
Chris
thanks,
Chris
Trying to decide between 4.33 gears and 26x10x15 Hoosier slicks or 4.56 gears and 28x10.5x15 ET drags.
I am leaning to the 4.33/26x10inch inch combo for NA use because if I ever decide to spray the car I can run ~137mph@7000rpm with a tire change to 28's and hopefully mid/high 9's <img border="0" alt="[devil]" title="" src="graemlins/gr_devil.gif" />
cheers,
Chris
<small>[ October 29, 2002, 11:57 AM: Message edited by: Chris ARE 360 ]</small>
cheers,
Chris
Chris,
The Richmond Gear PNs for the 8.875 series 4 12 bolt 4.33 are: Street Gear #6903781 and the Pro Gear is #7900741. Summit would use the manufacturor code 'RMG' as a prefix to either part number. Hope this helps.
Thanks guys, what about 4.56 gears. Strongest I can get <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
cheers,
Chris
cheers,
Chris
