help with putting together a 9" PLEASE
Old Jun 24, 2007 | 03:18 PM
WS6GoFast's Avatar
Default help with putting together a 9" PLEASE
m trying to put this f'ing thing together and i cant figure out getting the axles all the way in. I have one in but now i cant figure out how the hell to start a bolt for the backing plate, the bots are through the flanges but the holes are so close to the housing i cannont get the nut to start on them, is there susposed to be a nut on the back because mine were not tapped, i dont get how this crap stays together
its a moser 9" btw
thank you for any help i really want to get this thing together
-Matt
Old Jun 24, 2007 | 03:51 PM
skipshift's Avatar
Don't know if your having the same probs I was, but check out the post on DRIVER'S AXLE DOESN'T FIT. The backing plate holds the axles in.Make sure your bearings are pressed good.
Old Jun 24, 2007 | 03:59 PM
WS6GoFast's Avatar
bearings are pressed correctly and axle is all the way in im just trying to figure out how to tighten the backing plate
Old Jun 24, 2007 | 04:13 PM
skipshift's Avatar
I used a box wrench.Do you have T-bolts,or are you putting the OE bolt's in?There should be a hole in the axle hub to get a ratchet in.If anything take the parking brakes off to get in there.The nut should be facing toward the wheel.
Old Jun 24, 2007 | 05:11 PM
WS6GoFast's Avatar
i was using the OE bolts, i didnt know thats what the t-bolts are for, how do i get the parking break rings off?
Old Jun 24, 2007 | 07:43 PM
lethal93ta's Avatar
your kit should have came with t bolts, they go in from the back side and the nuts go on the plates.
Old Jun 24, 2007 | 09:01 PM
WS6GoFast's Avatar
yup, figured that out now, had to cut the stockers out and got it all solved, thanks for the help guys
Old Jun 25, 2007 | 04:23 AM
EPP's Avatar
EPP
For those who are pondering buying a Moser rear, and wondering about how hard the assembly is, I have instructions shown here. http://www.exoticperformanceplus.com....html?item=145 Bob
Old Jun 25, 2007 | 10:50 AM
WS6GoFast's Avatar
haha, i wish i woulda know about that
Old Jun 25, 2007 | 11:07 AM
xpndbl3's Avatar
yea i wrote that
