Is it winding a little high?
Old May 7, 2003 | 10:57 PM
2domn8's Avatar
Default Is it winding a little high?
This is most likely a stupid question, but here goes. I just bought a 98 TA. I love the car but it shifts from 1st to 2nd at 6600 (WOT). It feels like its about 600rpm to much. How can I adjust it? And just cruzing around town the 1-2 shift is hard and late feeling at light throttle.
Old May 8, 2003 | 07:27 AM
trackbird's Avatar
Default Re: Is it winding a little high?
I'm guessing that your tach is off. It seems to happen in many of these cars. My M6 has idled at 900 rpm (per the factory tach) since I picked it up from the dealer....new. I believe idle speed to actually be 600 rpm. So, it is likely that mine is off as well. You can adjust it with a Hypertech programmer (or Diablo sport, etc). The factory rev limiter is at 6200 rpm, so, unless it has been moved (by tuning), you are not likely shifting at 6600. I'm assuming that your car has not had any computer work done on it....if it has...then it may just need readjusted.
Good luck!
Old May 8, 2003 | 11:59 AM
hondakiller's Avatar
the 1-2 in my car feels harder than the rest of the shifts too. been like that since i bought it and i havent had a problem with it. kinda bothered me at first but im used to it now.
Old May 8, 2003 | 02:47 PM
trackbird's Avatar
adjust "it" was to adjust the shift points....not the tach....sorry...that was not clear.
Old May 8, 2003 | 10:20 PM
2domn8's Avatar
Thanks guys, not sure about the computer tune. Just feels like it falls flat right before the 1-2 shift.
Old May 8, 2003 | 10:31 PM
trackbird's Avatar
Valvesprings?
It could be old springs starting to float. I'venever seen a stocker do this...but it is possible.
