B&M megashifter question
Old May 8, 2003 | 01:50 AM
KMStevens's Avatar
Default B&M megashifter question
im swapping my t56 out for a th350, I have a B&M megashifter i got, and im going to cut out the stock 6 speed console to get it to fit. I havent looked at it a whole lot, is anybody running this shifter with a th350 or 400? where did you bolt the shifter down at? a local mechanic said i would have to weld in a piece of sheetmetal to the hole where the shifter came out from the 6 speed, i dont think that thats a good thing to do though. anybody have any ideas?
Old May 8, 2003 | 11:42 AM
megathumpzillaX's Avatar
Default Re: B&M megashifter question
cut a piece of 1/4" aluminum plat to the size of your existing hole plus about 1/2-3/4. Bolt that in, then bolt you shifter to that. Might need to mod the shifter mounts a little to get it to fit, just chop off what's in the way. The hole for the cable needs to go into the step-up portion of the tunnel, easy to drill. Hammer went in without needing to mod a manual console, you might be able to do that-where the shifter sits isn't as crucial as it is w/t56...you might be able to wiggle it in and even snip the top of your leather boot and make it look sweet.
I also twisted mine about 15 degrees away from the driver for a less weird angle-just push out and you're going the right way, forward and back parallel w/the car center was just not as slick.
