Went offroading in a camaro
Old Jun 26, 2007 | 05:48 PM
Intense's Avatar
Default Went offroading in a camaro
To make a long story short i go cut off in the rain and went of a center divider.
Since then my rear end hasnt been the same. The tires wobble when the car is in motion and I have done everything but take it somewhere.
Me and one of my buddys are thinking bent axle tubes. I want to take it to the dealer but I dont know what is wrong with it.
Any suggestions?
Old Jun 26, 2007 | 06:32 PM
styoung's Avatar
do just the tires or the whole rear wobble, i would check the panhard bar first, i could also be a bent axle, i cant see the axle tubes bending unless you really hit it hard, hope this helps
Old Jun 26, 2007 | 06:35 PM
Intense's Avatar
panhard bar is fine... the wheels wobble like they arent on all they way.. but they are. hit the curb at about 40ish
Old Jun 26, 2007 | 06:48 PM
styoung's Avatar
i would have to say its a bent axle, i would pull it and find out.
Old Jun 26, 2007 | 07:31 PM
Intense's Avatar
i think i am just gonna replace it haha chevy wants 200 just to look and i dont have the tiem to screw around with it.
Old Jun 26, 2007 | 09:57 PM
01CamaroV6's Avatar
Definately sounds like a bent axle. For $200 plus parts and labor to replace it I would make the time to check it myself.
Old Jun 26, 2007 | 10:11 PM
Jordan S.'s Avatar
Wanna buy some axles???
Old Jun 29, 2007 | 12:01 AM
ShevrolayZ28's Avatar
Make sure the rear is still centered. And you could carefully put the rear up on jack stands, chalk the front wheels, front and back. Start the car and observe the entire drive train while in motion. Maybe the problem will become more apparent.
...but it sounds like a bent axle or bent wheel.
Don't take it to a dealer if at all possible.
Lucky you didn't roll it or hit anything
Old Jun 29, 2007 | 08:31 AM
jay_99z's Avatar
They will charge you out the *** for the parts too. I would try to get a used axle and post up in your regional area. I'm sure someone could help you out.....even for a small fee. Probably get it done for a 6pack. That's the going rate around Charleston.
Old Jun 30, 2007 | 11:42 AM
Razor_Blade's Avatar
My money is on bent wheels. Let us know what it turns out to be.
Old Jun 30, 2007 | 03:01 PM
88zukon36s's Avatar
x2 check balance of the wheels..
Old Jul 1, 2007 | 07:45 AM
72ChevelleConv.LS1's Avatar
I have a bunch of take out axles with little to no run time. including bearings. the job is super easy to do. I can walk you through it. you can be done in 30 mins. just need to see how many splines you have and I can check to see if I have the correct ones for you. PM me
