1998 T/A rear-end: will it fit in an '85 Camaro???
Old 11-04-2002, 01:30 PM
Quickin's Avatar
Default 1998 T/A rear-end: will it fit in an '85 Camaro???
Thanks
<small>[ November 04, 2002, 01:31 PM: Message edited by: Quickin ]</small>
Old 11-04-2002, 05:04 PM
wm_sorg's Avatar
Default Re: 1998 T/A rear-end: will it fit in an '85 Camaro???
Yes. However you will need to use 4th gen rims bacause the rear is approx 2" wider on each side.
Emergency brake cable length may be an issue also. If you get the rear with the cables you should be fine.
Old 11-04-2002, 10:29 PM
99 Black Bird T/A's Avatar
Received 1,451 Likes on 1,007 Posts
I think there is a write up on www.thirdgen.org about how to do the swap and set the park brakes up so they work.
