Moser 12-bolt Torque Arm Bolts
If you stripped the bolt, just get another from a parts store like NAPA.
If you stripped the housing, you'll probably have to take out the rear and have the hole rethreaded. You might be able to do it yourself with the car jacked up to give you more room.
I don't know the bolt size but Moser SHOULD be able to tell you.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Also note you pronbably need LONGER bolts to go along with the thicker flange of the BMR TA. That along with the fact you *should* use a slightly longer bolt then Moser supplies in the first place (The threads are already there). Also get a nice Grade 8 Bolt for this. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Good luck!
Good luck!
