Problems with SPOHN TQ arm?
Old Nov 9, 2002 | 07:08 PM
F8L Z71's Avatar
12 Second Truck Club
Default Problems with SPOHN TQ arm?
I have one intalled and it makes a ton of noise and I think it is the cause of all my flase KR I am getting.
I never had KR till after I installed this unit the car is gettingdownright annoying to drive with it.
I have made exra room for the bolt that tends to hit the trans tunnel so that is totally clear. The noise is like a rattling/grinding feeling.
Anyone else had this problem?
How many people are running 10's with a stock TQ arm and not breaking tailshafts?
I am really thinking about trying a stock one again to see if my KR and rattling go away!
Old Nov 9, 2002 | 07:31 PM
mikey's Avatar
LS1TECH Sponsor
Default Re: Problems with SPOHN TQ arm?
Which arm? I have installed many of the 405's and never had this or heard of it.
Is it a Moser 12 bolt?
Old Nov 9, 2002 | 07:39 PM
F8L Z71's Avatar
I can't remember which model. There are only 2 that are adj. and mount OFF the tranny onto the G-load brace.
I have the standard one I think. Not the one for Grot headers. So I think it is the 405.
Durring normal accelration I do not hear/feel it much but deacceleration or off and on throttle it sounds like part of the car is falling apart. What could have been done wrong that would cause this?
Old Nov 9, 2002 | 07:41 PM
F8L Z71's Avatar
Ohh, I have the stock rear.
Old Nov 10, 2002 | 07:38 AM
mikey's Avatar
LS1TECH Sponsor
Check your pinion angle. That will cause a grinding noise if not set right. For a 10 bolt, I would go 0 degrees.
Old Nov 10, 2002 | 10:56 AM
F8L Z71's Avatar
Ok,
Right now if the car is on the ground the pinion angle guage shows almost -2deg. That is if I stick the guage to the bottom of the Diff, where the TQ arm connects and read it from the drivers side rear tire the needle points at roughly 11:58 if the guage were a clock. That would be negative right?
Old Nov 10, 2002 | 02:21 PM
DERTY's Avatar
The Bull
You definitely need to get your pinion angle right. You have to take your driveshaft angle minus the pinion angle to come up with the true pinion angle. Make sure that's what you are measuring, not the angle of the pinion itself.
Also, if your exhaust is within 1/2" of the crossmember, you may want to look at it closely. I had mine in there and the Y rattled at the farthest forward edge. Some intimitdation with a ballpene hammer may be required if that's the case. You'll be able to see the rattle marks if that's the case. I had all the same symptoms as far as hearing a rattle goes. Never heard it under accel or decel, just at idle speed.
Old Nov 10, 2002 | 03:39 PM
F8L Z71's Avatar
Ok,
I just looked at the pinion angle again (just the angle on the front of the Diff.) With my street tires on I have an angle of 0deg. When I have my slicks on it goes to -2deg.
So, if I want to get the true pinion angle I would measure my driveshaft angle, then measure my Diff angle (already got that). Then take the driveshaft angle and minus the pinion angle and that is my true angle? And that should be either 0deg or -2deg??
I hope you guys see this soon cuz I'm sitting in the garage with the car in the air and hitting F5 over and over looking for replies. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Thx guys. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
 Michael S. Palmer
Old Nov 10, 2002 | 03:40 PM
F8L Z71's Avatar
Ohh, it's not my exhaust. I already took care of those rattles. Those were simply annoying, this one is actually vibrating the car. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
