Do I need a Ring Gear Spacer
Old Jul 12, 2007 | 04:48 PM
Mohammed's Avatar
Default Do I need a Ring Gear Spacer
I'm about to buy 3.73 gears . Do I need to get a ring spacer ?
I'm asking cuz I have 2.73 in the car and I saw somewhere that if you have that gear you gonna need RING GEAR SPACER, is that true ?
Old Jul 12, 2007 | 05:59 PM
02sleeperz28's Avatar
Your absolutely correct a spacer or a 3 series carrier. a spacer is cheaper. which ever one you chose just make sure the install of the gear is correct.
Old Jul 12, 2007 | 06:10 PM
Mohammed's Avatar
thanks for responding
Old Jul 12, 2007 | 08:06 PM
mzoomora's Avatar
14 Second Truck Club
Just buy a thick set of gears. They usually have an X at the end of the part number, they are made to fit a 2 series carrier and it is better than using a spacer and cheaper than buying a new carrier.
Old Jul 12, 2007 | 08:10 PM
I agree with you about the thick set of gears, I forgot about that. Strange sells then. I used Strange thick gears in my old car. no wine or anything. Good luck again
no problem
