rear end questions
Old Jul 6, 2007 | 02:08 AM
Ah7394's Avatar
Default rear end questions
My 98 T/A has a bit over 400 HP and sits on drag radials. Can my rear end take it? or if i take it to the track to run the 1/4 am i going to break it?
Old Jul 6, 2007 | 02:09 AM
Ah7394's Avatar
stock rear end by the way
Old Jul 6, 2007 | 02:52 AM
chicane's Avatar
It would help all involved to know a little more before we try and answer your questions.
Things like engine, transmission (if an auto, the converter specs... etc), gear ratio, modifications to anything engine, drivetrain or suspension would be of great help.
In short... can it take it ?? Well yes... but only to a point. When that point is, becomes the real question. If you take it to the track and run it, will it brake ?? Well... yeah. That's not really a question of "If" it will brake... but more of a question of "When" it will brake.
Answer the above inquiries and help us, help you.
Old Jul 7, 2007 | 04:07 AM
revtime's Avatar
your just going to have to roll the dice. It may hold for awhile and it may break on the first hard launch.
Mine broke on the street with Bridgestone RE730s. I was running a full manual valve body TH400 though.
Old Jul 7, 2007 | 05:50 AM
EPP's Avatar
EPP
Smile
I've had people call me to order Moser rears, and many have told me how their 10 bolt broke. It ranges from stock power in one week to two to three years on a built combination. I heard of one guy who said his 10 bolt broke backing it out of the garage... Bob
Old Jul 12, 2007 | 02:30 PM
phantomLT1's Avatar
Default Your rolling the dice
Mine broke one time making a right hand turn and slowly accelerating on freeway I am making the same HP on my motor
Old Jul 12, 2007 | 07:58 PM
keliente's Avatar
Old Jul 12, 2007 | 08:11 PM
Jbmoney21's Avatar
If you are 6 speed and you HOOK good its not gonna last long. You can try to be easy leaving out the hole and dont drop the air pressure to low
