12 bolt studs are short
Remember back in elementary school / middle school... Cool guys took pencils and put them between there finger and slammed their hand down on the table to see how small a length pencil you could snap with out being in too much pain... well the smaller the pencil the harder it was to snap it or you could not at all. Same concept with shortening axles etc. BUT again the material and diameter of the axle and or wheel stud etc. plays a larger roll in strength always. Also in the rule books for faster classes it is required to see the stud protrude past the nut. Ease of inspection. for measuring diameter etc.
If the stud is flush with the outer flat edge of the nuts your cool. less and think about getting longer ones. Does your car use Disc brake set-up? have you installed it from another car if you do? Jim
If you are really concerned, you can probably replace the Moser studs with ARP.
-Mike
-Mike
Also, my ZR1's were heavy. How heavy? Well, I dyno'd 333rwhp with the stock 16" rims. After making no other modifications to the car aside from changing the wheels and tires, I dyno'd 320rwhp. Add the unsprung weight of a 12-bolt, and my car started handling very rough.
I've always liked Fikse FM/5's. The right deal came along on a set of four 17x9.5" FM/5's, and I jumped on it. Lighter, no more rubbing, and (IMO) they look better.
-Mike
