Shifting difference in D and OD
Old Nov 13, 2002 | 10:06 PM
Phil99TA's Avatar
Default Shifting difference in D and OD
Is it normal for an A4 to have a big variation in WOT shift points from racing with the shifter in Drive and then having it in Overdrive? What would cause such a difference (600+rpms)?
Old Nov 14, 2002 | 08:33 PM
Sears's Avatar
!Dial-up Director
Default Re: Shifting difference in D and OD
Not an A4 guy, just passing on info from a friend ( "So Slow" on here ). His car would not shift into 3rd when left in D, but put it in OD and problem solved. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Sounds like it is a common problem?
Justin
Old Nov 14, 2002 | 08:59 PM
jimmyblue's Avatar
Moderator
Mine just "seems" like it shifts harder,
higher with the selector in D. It wouldn't
surprise me that some subroutine somewhere
is interpreting this as a "sport mode".
Although I wouldn't go so far as to claim
it.
Mine is a happy 1-2-3 in D.
Old Nov 14, 2002 | 10:18 PM
Colonel's Avatar
Not unusual. I used to notice when my shift point/rev limiter point was set tight I had to run it in OD or I'd hit the limiter.
Old Nov 14, 2002 | 10:24 PM
horist's Avatar
I think it plays with the line pressure leaving it in 3rd.
I have experienced alot of oddities leaving it in 3rd but never a problem staying in OD
