Noise from rear: WoWoWoW what is it?
Old Apr 18, 2008 | 09:13 AM
98RedZone's Avatar
I had my right rear axle bearing go bad and wreck the axle. It sounded like a flat spotted tire.
Old Aug 22, 2008 | 05:28 PM
brandotron's Avatar
Default Back from the dead!
I have the same wooshwooshwooshwoosh noise and I'll be tearing it apart tomorrow to change the fluid and figure out what the deal is.
Worst case scenario, I can't change the bearings right away. Is it still safe to drive? Is the noise the worst thing I have to worry about, or should I be worried about the rear end seizing up and getting towed home? Dumb noob question I know, but I never had to worry about this in my thirdgen. Nice job General
Old Aug 23, 2008 | 09:42 AM
LT1Formula26's Avatar
mine moans mostly when i turn at very low speeds. what could cause this? bearings? checked the fluid and it was a little high, but not dirty or anything. also, when i am at high speeds on the highway like 70-80 just cruising, if i turn the wheel to the right, i feel a vibration and a slight noise, but when i turn the wheel to the left it goes away. this just started happening a couple days ago, but the rear has moaned at low speed turns for a long time.
Old Aug 23, 2008 | 10:57 PM
som1sc's Avatar
Thats what mine is doing. Turn to the right makes noise at the left rear. sounds like the brakes dragging. Wonder if its the axle bearing?
Old Aug 25, 2008 | 12:46 AM
yea sounds exactly like mine.... it doesn't seem to be getting worse, but im curious to know what it is...anyone help?
