Is my posi bad?
Old Jul 22, 2007 | 09:54 AM
zzz28's Avatar
Race Fan
Default Is my posi bad?
I know nothing about the posi but from what i've read in other posts is that the 99's came with posi. My car is basically a one wheel wonder. When ever i burn out or launch just the passenger rear tire spins and smokes and you can see a huge differance in wear. The driver side rear tire looks brand new where as the passenger side has almost no tread left. Is there something wrong with the posi unit or is there just no posi?
Old Jul 22, 2007 | 01:56 PM
alamantia's Avatar
if its an auburn just dump the fluid clean out the housing with some brake cleaner and fill with 2 quarts conventional 80w-90 GL5 lube and a bottle of limited slip additive and you should be good
