? about transbrakes
LAter <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Will
Maybe there's some setups out there I haven't seen yet. I have a t350 with an ATI transbrake. Let me describe to you how mine works.
I pull up to the line, and activate the tbrake ( its controlled by a solenoid thats activated by a simple button switch ). When the solenoid is activated the t-brake engages 1st and reverse. When ready I stand on the accelerator , and try my best to cram it through the floorboard. The motor then revs up to my approximate stall speed on the converter. It doesn't go up to the rev limiter. When you release the button it relases reverse, and bam... you spin, you break, or you go. When selecting a converter you need to tell em you are gonna be using a t-brake, and what rpm you want it to stall at on the brake. Mine stalls around 4500 on the tbrake.
reasons for using a two step:
when using my technique described above, the rpm that the converter stalls too can be inconsistent, due to fluid levels, tranny temps etc. You can use a two step to set the engine rpm revlimiter temporarily so that on every run your launching off the exact same rpm to improve your consistency. But as in my case ( with a stall of 4500 on the brake ) if you were to set the two step limiter to say 5000 rpm, it would be like not using the two step , and the converter would still stall out around 4500 ( if that makes sense ), you basically use the two step to bring your limiter down below your stall speed of the converter.
I've also been told that when you do use a two step, and have it set below the stall of the converter, that you can get that extra smack out of the converter when you release the brake, and it flash stalls up to its limit, which can result in some harder launches. Haven't tested this yet but since my car seems to launch best around upper 4k off the brake....I'm thinking about raising my converter stall to 5000 or 5500rpm , installing a two step, and setting the two step to launch around 4500 - 4800 rpm.
Hope that helps, You might ask GeorgeC or BeaSSt they also run brakes. Email me if you have any other questions. You can also look at that video of my car I took from inside, you can see on the launch where it stalls at around 4800 on the brake.
Larry
This is incorrect. It WILL NOT go to the rev limiter. This is impossible. It will go only to the true stall speed of the converter (which of course is nowhere near the stall speed of the converter.)
Ya'll please be careful with the false information. If you're not %100 just let someone else give the information. This forum is only as valuable as the accuracy of it's information. Thanks! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
For instance, my new engine is probably going to turn about 9000 RPM. The 2-step will probably be set around 6500. To the casual onlooker (onlistener?) it will seem to stall "to the sky" but still, it'll be a good 2500 RPM below the rev limiter and about 500 RPM lower than the stall speed.
If I disconneted the 2 step or set it higher than the stall speed, the engine would go to the stall speed (7000 is this example) on the brake.
<small>[ November 17, 2002, 03:45 PM: Message edited by: Colonel ]</small>
