What gear?
Old Nov 18, 2002 | 11:12 PM
ElectricBlueTA's Avatar
Default What gear?
i dont know what kind of gear i have...i'm doing 60 MPH and i've got 2,000 RPM does n e one know? cause my friend has a 98 6 speed and it has a 3.42 and he is doing about 18-1,900 @ 60 MPH.
Old Nov 18, 2002 | 11:33 PM
Jason99T/A's Avatar
I can shift faster than you.
Default Re: What gear?
I wouldn't put too much faith in the stock tach reading. Find a scan tool and hook that up to see what RPM you are actually at. +/- 200 rpms is very common between years.
Old Nov 18, 2002 | 11:54 PM
hondakiller's Avatar
look on the door sill, gu2 is 2.73, gu5 is 3.23 and gu6 is 3.42 but you wont have gu6 with an auto car.
Old Nov 19, 2002 | 08:09 AM
AZ28driver's Avatar
60 mph and an M6 in 6th gear should let you lope along at 1,300 RPM. If you are pulling close to 2,000 rpm in 6th year then your gears have been switched to 4.10
