Proper gear backlash
Jim
jusy my .02' , Johnny
It is and has been a "rule of thumb" to use 0.001" for every inch of ring gear.
With that said, 7.5" would be 0.0075" or betwen 0.007 - 0.008"... unless specifically directed by the component manufacturer differently. But... remember, this is only a guide line. Even though the manufacturer says to use x.xxx" that itself is a guid line number as it does not take into account for housing irregularties.
I say set it up for 0.008" and and take a look at it. If it doesnt look like the way you want it... change it. Its that simple.
Are these trans brake launches? Seems like the ring gear would see a huge impact load with a large clearance.
try http://www.aam.com/file.php/255/axle+shaft+brochure.pdf and go to page # 41 for correct setup
