best torque arm for the buck???
Old Nov 20, 2002 | 05:21 PM
Air21's Avatar
Default best torque arm for the buck???
need an adj toruque arm to with the adj controls arms. What the best one for the price?? The top ones are running $700. I just need something good enough for 10's.
Old Nov 21, 2002 | 11:38 AM
talonis's Avatar
Default Re: best torque arm for the buck???
I'd say the Spohn one should suit your needs.
Old Nov 21, 2002 | 02:51 PM
99MONGOOSE's Avatar
Believe it or not, there are several guys running mid 11s to high 10s on the stock arm. Main problem is if the bolts loosen or back out a bit, that gives the arm a chance to flex and break. One of my bolts backed out and I ripped the upper half right off the 12 bolt case. Luckily I didn't get the the track yet. It broke as I was messing around on the freeway, on the way to the track.
