Transmission Pan
Old May 21, 2003 | 12:03 PM
jlrz28's Avatar
10 Second Fun Car
Default Transmission Pan
Was wanting to know if anybody had put a deep transmission pan on a A4? What kind did you use and any clearance issues or is this just a dumb idea? I have a 3200 Vig converter and live in Houston where its hot this should cool down the fluid quite a bit. Any suggestions would be appreciated.
Thanks
Old May 21, 2003 | 12:59 PM
SteveC's Avatar
From: Poway, Ca. where GOD and the sun always shines
Default Re: Transmission Pan
A few months back I had a B&M 24K transmission cooler, and a B&M aluminum 3Qt. deeper pan installed on my 2001 Z28 A4. This particular pan does hang down quite (sp) far, however not as far as my 3" round Y pipe, and not nearly as far as the SLP bolt on subframe connecters. My car is stock height. I do not have any problems in bottoming out when going over dips or speed bumps. You may have some issues using this pan on a lowered vehicle.
Hope this helps you out in some way.
SteveC
Old May 21, 2003 | 03:57 PM
Honez's Avatar
I read that some of the guys put on a pan from the Chevy Taho, it has a plug and is a little deeper. I think there are dealers that will sell it for under $100. I wish I had a part number for you but I'm sure that if you called the parts counter they would confirm that the gasket is the same.
Old May 21, 2003 | 06:55 PM
Jay 95WS6's Avatar
the truck pan is deeper and has a drain plug and there is a specific filter for that pan email me slapsht25@comcast.net for the part #'s
Jay
Old May 23, 2003 | 01:07 PM
5150Z28's Avatar
When I got my trans rebuit I had them put a GM truck trans pan on. It holds an extra quart and has a drain plug. Make sure to get the longer filter.
