Help need ASAP: How to remove axles from 9 inch?
Re: Help need ASAP: How to remove axles from 9 inch?
If I'm not mistaken for a 9" since they dont have c-clips you just pull the wheel off, take the brakes off, then unbolt the backing plate and the whole thing should just slide out. I know this because my backing plate bolts came loose on me while driving and my whole axle/wheel/brake assembly came out of the car.
Will
Will
whoa! axle came out while you were driving?!?!?! <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Yah it was crazy. I posted about it when it happened. Here's the link.
https://ls1tech.com/ubb/ultimatebb.p...=004539#000014
Make sure to check your backing plate bolts frequently. It's easy to check em and will save you a scary time should they come off. Mine have plenty of red locktite on them now
Will
Will
