making noise
Old Aug 13, 2007 | 12:09 PM
artic-z28's Avatar
Default making noise
Yeah I broke my drive shaft right at the yolk. now its making a squeaking noise?
What the hell is it? sounds like its coming from the rear maybe.
Old Aug 13, 2007 | 12:34 PM
Jon5212's Avatar
Sounds like your U-joints are bad, if you broke it you probably screwed up your u-joints as well.
Old Aug 13, 2007 | 12:36 PM
artic-z28's Avatar
I just replaced them,, do they need to be greased more?
Old Aug 13, 2007 | 01:14 PM
artic-z28's Avatar
ok that noise went away. now it has like a poping noise underneath it... like its hitting something,,
Old Aug 13, 2007 | 01:23 PM
Jon5212's Avatar
Oh man... You got me now lol... maybe you fubarred the pinion shaft itself? Check your lower control arms make sure they are tight... when does this sound happen? Upon acceleration? Deceleration? Coasting?
Old Aug 13, 2007 | 01:42 PM
artic-z28's Avatar
went i let off pretty much
Old Aug 14, 2007 | 05:38 AM
EPP's Avatar
EPP
Check out your transmission mount, as they tend to break quite easily. Also check out your torque arm, the factory one starts to bend about six inches forward of the rearend. Bob
