Strange v. Moser
WQhat are your thoughts? Which 12 bolt is better?
Mike B.
<strong>The Moser is a bit cheaper but it does have the problems of the torq arm bolts backing out. You really need to keep an eye on them. The Moser uses 4 short bolts rather then the OEM 10 bolts 2 long bolts and nuts. I hear the Strange uses the same set-up as the OEM 10 bolt but I don't know for sure. Can anyone chime in that has the Strange to verify this?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">DTS which are KTRE housings uses the same 4 bolts as the Moser. I know guys with them backing out is because the didn't put in a lock washers, or really tighten them down with a long 1/2inch drive pivot wrench to over 100ftlbs. Only way to do it is on a hydrolic lift with the rear end all the way down. Since the bolts aren't supplied you should get the longest possible length of 1.5 inch 8pt bolts and tighten the **** out of it.
Leo
Mark
Also how difficult are these to install? I plan on having it sent to my house and doing the install myself(with help of course) and need to know how difficult this will be. And any sites that might help me along the way.
Thanks for all your help guys.
Mike B.
<strong>I got my Strange from Tbyrne.It did take about 5 weeks to get it.The install is very easy.Unbolt old,install new.I had 2 people help me by they held the brakes and I slid out the old rear and put the Strange right back in.I think it took less than 2 hours to do.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Did you pay for the preinstalled brake backing plates? I've heard you need a press for some part of the install. Something about an ABS component needs to be removed from the old 10 bolt and installed on the new rear. It might have been called an ABS exciter ring, but I'm not positive. Just trying to get all the info I can about the install and what it will take start to finish.
Thanks,
Mike B.
<strong>Go with the Strange if it uses the 2 bolt T/A mount like stock. I have a Moser and if I could do it again I would get the Strange.
Justin</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanks man. These kind of endorsements really mean a lot. It's one thing to spend a lot of money on something and then go around singing it's praises to make yourself feel better. but it shows a lot of integrity to to say here's what's the real deal is and try and help someone else out before they make a similar mistake. Thanks Justin.
Mike B.
Thanks Guys,
Mike
