Moser 12-bolt: A Work of Art
Old Nov 26, 2002 | 08:23 AM
Jax White TA's Avatar
Default Moser 12-bolt: A Work of Art
I have to say that this is the most well engineered, thought out item I have ever installed that is such a major part of the performance of a vehicle. We had the assembly in in less than an hour. Everything else maybe took another hour from removing the old brake backing plates to hooking up the sensors and what-not. Everything fits perfectly, nothing is out of whack or needs a BFH to be put in place. I was ready for a HUGE headache doing this in the garage floor but its a cakewalk. Tomorrow we are pressing the bearings on the axles and a new u-joint and in they go. Bolt the calipers on and its done. I just cant believe how easy and straightforward this was. I have some pics below for your enjoyment. I pulled the rear cover off and needed a moment to myself after seeing the beefyness of the internals compared to what I had before. Enjoy!!
Complete assembly
Axle comparison
Axle comparison again
TA Girdle
Installed in car
Internal
Spline comparison
Old Nov 26, 2002 | 05:22 PM
MIGHTYMOUSE's Avatar
Default Re: Moser 12-bolt: A Work of Art
i think you will need to paint it if you want it to stay looking good, at least some clear, it will rust up in a hurry.
i went for gloss black on mine.
those 33 spline or what? i never looked into mine before installing.
Old Nov 26, 2002 | 07:13 PM
LS1LT1's Avatar
https://ls1tech.com/ubb/cgi-bin/ulti...c;f=2;t=005092
Unfortunately not everyone shares your sentiments about Moser 12 bolts. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Old Nov 26, 2002 | 07:29 PM
Elite_Hot_Rod's Avatar
What size gears are those? My rear end should ship tomorow from Moser.
Old Nov 26, 2002 | 08:58 PM
theblur98ss's Avatar
If you don't have the bearings pressed on yet then I'm guessing you haven't tried to put the abs sensors on yet. I had to grind notches on the end of my tubes for the sensors to clear. Mine was a 4 channel setup. I still can't believe a $2500 rear end doesn't come with 8 nuts needed for the install.
Old Nov 27, 2002 | 07:06 AM
Those are the 33 spline axles and I got 3.73 gears. I pressed the bearings on last night and I have 3 channel ABS so I dont have to worry about the exciter rings on the axles. And yes, I have to go buy some nuts today. I wonder why they dont supply them?
Old Nov 27, 2002 | 09:01 AM
jimmyblue's Avatar
Moderator
Saw somebody had an axle come out,
because those end nuts backed off.
So Loctite 'em, or get some good
interference type nuts that won't
walk.
