WHAT'S A DRILL MOD?
Old May 26, 2003 | 12:51 AM
1320_PERFORMANCE's Avatar
Default WHAT'S A DRILL MOD?
IM KINDAH NEW @ THIS KINDAH STUFF. WAT DOES A DRILL MOD DO? DOES IT MAKE A DIFFERENCE PERFORMANCE WISE? HOW DO U DO IT. THANKS IN ADVANCE
Old May 26, 2003 | 05:04 PM
pimpmaro's Avatar
Default Re: WHAT'S A DRILL MOD?
Look at www.installuniversity.com. That has the drill mod instructions stuck in with the McLeod adjustable master installation. It shouldn't be too hard at all for you to go in and pick out the drill mod steps. Good luck.
Old May 26, 2003 | 08:10 PM
2000Z28M6's Avatar
Can someone explain how it helps the stock setup performance wise? Is this mod aimed at just getting more fluid moving faster. I want to do it if it will stop or help my clutch from sticking when redline shifting.
