Torsen shot, recommendations on replacement diffs?
Eyewitness reports from beside the burnout box state that only one wheel is spinning properly during burnouts. Any suggestions on a good replacement differential? Should I stick with another Torsen? Or should I get an Auburn? Or is there a better (more heavy-duty) alternative?Any suggestions and/or insight on what I should do would be appreciated
Thanks in Advance
-Bradster
Anybody want to cast a tie breaker?
Or another alternative?Thanks for the speedy reply guys
Any other suggestions?
TIA
30,900 HARD
N2O miles
on mine and not a single problem yet! http://www.torsen.com/products/T-2.htm
http://www.torsen.com/products/T-2R.htm
Does it do it on normal driving on the street when you punch it?
BTW...I split my Torsen housing in half...got another Takoff usit from SLP for $99 and its held up to many 10 second passes since.
ProStock John advised to me that it might be just low fluid in the differential. I am going to check on that tomorrow, I hope that is the case.
Up until I was told about my burnouts, I didn't notice anything wrong with how the car launched on the street. Of course, I rarely, if ever, launch on the street as hard as I try to do at the track. Still, even during "spirited" launches on the street, the car never gave me the impression that anything was wrong - it always tracked staright ahead and hard.
Anyway, I hope I don't have a problem - I'll likely have it checked out by professionals just to make sure. If I do need a new diff, I think I'll go with a Torsen again
Thanks everybody for all the feedback
I'll post what I find out tomorrow (gotta find a place to "test" it again without getting a ticket
)-Bradster
right tire enough to spin it, and the difference
between static & sliding friction is more than
2:1, you only spin one wheel. That's totally
normal.
Torsen T-2R has both a higher available split
ratio (like 3:1) and preload springs (so you get
a built-in bias, and the sticking wheel gets 3X
spinning wheel torque, plus friction bias, instead
of 2X.
Torsen is best for non-straight-line driving by
far. T-2R will compromise this at the limits,
give you cornering wheelspin earlier (but on
the lighter-loaded inside wheel, where others
may tend to spin the outside, critical wheel).
T-2R is not easy to find but worth looking for,
I think I've seen pricing like $399 or so which
is not out of line with other chunks.
I wish I knew if a regular T-2 could be after-
modded to alter torque split and add preload.
I checked the fluid level in the differential today and it was WAY LOW!
I couldn't get the last 1/4 of the bottle in there because there was no room under the car to tip the bottle properly to empty it into the diff. I bought another bottle and will fill the diff up to it's proper level tomorrow at work.I have no idea where the oil went. There is no signs of a leak in my parking space. The only thing I can think of is that when I had my rear end girdle put on (like a year ago), initially there was a leak from a loose drain plug. I had it fixed, but I assumed that the differential was refilled afterwards.....
Anyway, I am sure the low oil level was at least partially responsible for the "wierd" burnouts. I just hope I didn't damage anything in there by driving around with very little oil in my differential for so long....
I guess I'll have to "test" it again sooner or later - I couldn't do it today. There were way too many cops everywhere on the northshore for me to be doing any burnouts or launching really hard from a stop light or something.
Thanks again everyone for the great feedback. I'll post what I find when I get a chance to test it out again.
-Bradster
