bleeding process question...
Old Dec 5, 2002 | 07:30 AM
1badvr4's Avatar
Default bleeding process question...
when bleeding the master/slave do you have to have the trans bolted up completely?
Old Dec 5, 2002 | 07:57 AM
1badvr4's Avatar
Default Re: bleeding process question...
or, i should say, should the slave be compressed?
Old Dec 5, 2002 | 10:22 PM
MIGHTYMOUSE's Avatar
yes if you dont have pressure on the slave you will blow the throwout bearing off of the end of it, but unless you really goofed bad you can re assemble it without issue.
fill the reservoir, pump and hold the pedal, crack the bleeder, pull pedal up and repeat process.
