putting a 4-channel rear in a 3 channel car?
Old 09-08-2007 | 10:43 AM
echo3313's Avatar
Default putting a 4-channel rear in a 3 channel car?
What do you have to do to put a 10-bolt 4-channel rear end in a car that came with a 3-channel?
Old 09-08-2007 | 03:03 PM
camaroguy26's Avatar
you have to get the ring adapter or a 3 channel carrier with it on it with all the teeth on it for the sensor to read in the housing. Then you have to drill a hole and install the sensor to read it.
I'm pretty sure you can use the 4 channel axles for the 3 channel, just can't do vise versa, use 3 channel axles for a 4 channel.
Old 09-08-2007 | 05:33 PM
echo3313's Avatar
nevermind saw the sticky!!!!
