how to replace strange 12 bolt axle seals??
Old 09-13-2007 | 08:17 PM
redtail2426's Avatar
Default how to replace strange 12 bolt axle seals??
How do you remove the two axle seals on a strange 12 bolt.It has the tapered style bearing.It appears that the bearing needs to be pressed off the axle and the race pressed out of the axle housing so i can get both seals out.If anyone knows of a tool i can use in my gagrage that would help a ton.I dont have a press either.thanks
