Moser 9" - Brand NEW and NOISY!
LS1Tech Sponsor
Originally Posted by IROC403
MY moser 9 whines bad. I took it appart and checked the pattern and it wasn't
even close. I had to add .009 shim to correct it but its too late,the gears
are junk!!!! thats what I get for not checking it myself. I asumed that
moser has set up gears before so I just put it in.
Wow, having to add .009 pinion shim is really way too much. What was your final shim thickness?
doing what they said "drive it around and see if it quiets down"
Ill call moser tomorow and see what they will do. I cant send it to them
first because its my only car at this time. if they do nothing. I just have to
buy a set of gears and set it up myself. There parts seem great quality,
the set up is just rushed or something.
LS1Tech Sponsor
I think it ended up being 21 total, thus after the gears ground up by
.012 Pinion shim isnt even close to what I have come across. let me know if you need a helping hand.
Scott @ DLS
LS1Tech Sponsor
Originally Posted by chicane
Yeah... the only time I have used anything that low... was with really deep gears or 8620 Pro set's.
I've set up 9310 Pro gears in a few M/W cases and they are around .015-.018 with ball bearing pinion supports instead of the large taper bearing style.
Yeah... well they dont make 8620 Pro sets any more. I think the last time I actually saw a set was back in the late 80's. The new ones ahve been on the lower end of the scale, as you noted. Hell... on that note, for the standard 8620 street gears they have been between 0.018 to 0.028"
0.012" is still rather odd tho...
I am expecting to see something similar. It still has noise, can't say anything has improved. Got 150 miles oin it now, its coming apart. Something ain't right.
![Disgust](https://ls1tech.com/forums/images/smilies2/disgust.gif)
How many miles had you put on yours?
A few 1.7 60 ft runs and on the way home it got really stupid loud!!!!!!
whan I took it appart the gears were scored + verry un-evenly worn.
I ordered motives from my local speed shop ($180)
I will install them wed. night.....if I just checked the pattern in the begining
they would be fine but moser said to drive it, they suck
![Ripped](https://ls1tech.com/forums/images/smilies3/ripped.gif)
Originally Posted by red_ryderSS
If u could post where u got this rear from so we can decifer whether or not its a common problem with that company/sponsor. Also because I am in the need for a 9inch and would help my decision from where to buy from. Good luck with sorting out the problem.
Scott@ driveline seems like a stand up guy to do a good set up.
he offered me help to correct my horror show.
#34
Originally Posted by getusum
I have a moser 9 that I bought from Bob at EPP.....Bob and his company are great.....Can't say much about the rearend.....has whined since day 1....
Same here. Shud have checked it before I put it in. Im gonna put new gears in this winter. I've assembled alot of gears and never had this much noise. Mine is really loud and annoying. My girlfriend wont even ride in it any more.
#36
LS1Tech Sponsor
Motive Performance or Strange pro street gears are top of the line IMO. I tend to stay away from Richmond, Motive blue box, Zoom, and now Precision Gears unless the customer brings or demands them.
#37
So I put in my new gears today because moser screwed up my first set,
and I find a ring gear spacer?????I may be new to the 9 in. but isn't that
what you use when you dont have the right carrier, is this normal?
or did they screw me even worse than I thought
#38
I have heard this about Motive gears more than once being a good way to go, did not know about a 'blue' box set though.
thanks for the info.
I see I am not the only one with a complaint on Moser pre-assembled center sections, what a shame..... well that is why I put this thread out here. At least the housing was nice or wait a minute, should I slide a narrowing jig through the axle tubes to be sure they are straight so that it won't kill the axles/ and or bearings in 5k while it is apart?
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
Can you tell I am a little T'd off?
![Nutkick](https://ls1tech.com/forums/images/smilies2/nutkick.gif)
#39
man, how can Moser do this? you'd think they would save money in the long haul if they setup their gears right the first time. but from what i'm hearing in this thread moser just gives you a big "f*** you" when you call em up and say that the rear is setup wrong. this is discouraging.
#40
I also feel screwed by Moser my 9" was ordered with a complete aluminum center section that has leaked from the pinion seal from day one and with less then 30 passes no more posi just one wheel pulling. So much for the Auburn posi upgrade. The rear was always loud and when you talk with them on the phone you get alot of bullshit.
