Moser 9" - Brand NEW and NOISY!
Wanted to pass along this info. I guess you could say I am not really too happy. Not slamming anyone..... but just putting this info out there.
Installed a NEW Moser 9" complete with Detroit True Trac and 3.70 gear into my 2000 Camaro SS. Followed the break in procedure to a T. Ran 2-3 minutes unloaded on the lift and let cool overnight. Drove the car for 10 miles the next day at varying speeds (accel and decel) and let cool overnight.
There is pronounced gear whine on decel. Short of it, gears are not set-up correctly.
You would think that if your business was to set-up ring and pinions all day everyday you could get this right.
My buddies Strange rear end is quiet as a mouse.
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
LS1Tech Premium Sponsor
no noise here... I did my own!
www.ls1tech.com/forums/showthread.php?t=781110
unfortunately, most of the bigger companies are just pushing parts out the door to make the buck and don't really look at the quality of what goes out the door. just collect the money and worry about the customer later.
If u could post where u got this rear from so we can decifer whether or not its a common problem with that company/sponsor. Also because I am in the need for a 9inch and would help my decision from where to buy from. Good luck with sorting out the problem.
It is a Moser 9 inch, which probably was dropped shipped to him from Moser. We installed a set of 3.73 Richmond gears into the APS Firehawk that we built last week, we set the gears up correctly, etc. The car had gear noise for two days then it went away. The customer said the gears are quieter than the 4.10 gears we had removed from his 12 bolt. I'd give the gears a week to break in and see if they quiet down. Bob
I drove the car for another 20 miles tonight at highway speeds. The gear noise is still there, I would be really shocked if it goes away with more driving, but I will continue to put some miles on it.
Tomorrow is my scheduled dyno time, that probably won't be easy on the rear. I am under the impression that this early in the game the gears could be re-setup and saved.
Anyone know how many miles could be put on a set of gears before they won't set-up again in another location without noise? I have heard mixed opinions. All of this is assuming it is the set-up and not the gear itself. Two local drivetrain shops I work with did not hesitate to say it was the set-up when I mentioned gear whine on decel. I have some pretty strong faith in these guys as I have used them in the past.
Whatever it is, it is not what I expected from a professional shop (Moser). I would have had a 50% shot of setting them up myself to get them this quiet and I don't build rear ends or profess to be an expert, at least at gear set-ups, which is why I bought it from someone who I expected to be.
After the tuning is done tomorrow night I will drive it some more, Saturday and Sunday, and try to get a couple hundred miles on it. If it is still noisy, I am pulling the chunk Monday and going to paint it up and see what it shows.
I bought the rear from a reputable vendor, that isn't a worry for me. Moser's QC is what bothers me. I kick myself for not painting the gears and checking the pattern the whole time I sat on the rear before installing it. The thought crossed my mind but I didn't take the time.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
I have to tell you that this thought has crossed my mind too. What pisses me off most is I know better. I took the path of least ressitance on this one and it looks like it may bite me. The only part on the car I didn't do myself and it turns out to be my only problem.
I was hoping to do a little racing at the track next week too.
I will kinda side with Bob on this one. Give it a few days and a few more heat cycles... and then change the oil to an 85-140wt (or thereabouts) before you go and beat it up on a dyno.
As for how many miles you can put on a diff before it work hardens the pattern (and noise) into it... I would say that number is 200-250 miles and under.
Check your pinion bearings preload. Mine were not loaded enough and bearings were loose (It changes gear mesh and can cause whine). I had to grind the solid spacer between the bearings to get it right (15-20 in.pound). It cured the whine for me
SSDION
SSDION
I had a local shop set mine up four times. A friend and I saw the pattern each time and it looked fine. The noise is still there. He made it a little quieter. It's a Strange S case, Tru-trac, 3.89's. I guess it's just a noisy set of gears? Well I hope it is. I don't want it to destroy itself.
![Exclamation](https://ls1tech.com/forums/images/icons/icon4.gif)
Great, that is what I just ordered, I hope mine doesn't make a lot of noise.
Wish me luck.
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
Just fart against a wooden chair, see sounds like your rear end! No just kidding man, good luck and i hope it comes out right. It might give you some peace of mind to just inspect it yourself and just give it some time before you head to the dyno. Dunno, just hope it gets fixed for you man.
LS1Tech Sponsor
Wish me luck.![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
Wish me luck.
I don't dropship my center sections from Moser, I hand build everything in house with my own hands...
I know you do but other vendors drop ship, Moser build rep isn't always the greatest.
I Can't wait to get my new 9", not driving my car is driving me nuts, good weather is almost done.
MY moser 9 whines bad. I took it appart and checked the pattern and it wasn't
even close. I had to add .009 shim to correct it but its too late,the gears
are junk!!!! thats what I get for not checking it myself. I asumed that
moser has set up gears before so I just put it in.
