How hard is it to do a gear swap?
https://ls1tech.com/forums/gears-axles/412366-rear-end-faq.html
For some reason the 8.8's are always easy. But when I did my camaro rear it was the worst ever it just would not set up right. Took me about 12 hours on and off.
What you're going to find most difficult is judging whether or not the contact pattern is correct. Sometimes it's perfect on one side and no where close on the other (drive vs coast sides). Then you have to figure out what to change to make it right.
Be sure you write everything down as far as shim size, locations, notes on what the pattern looked like with that shim set up, etc. The judgement part is the most difficult, nothing you read will teach you that.
