another thought for strengthening 10 bolt....
as i said, i was looking through jegs, and i saw that eaton makes posi units for 10 bolts. it is a 7.625 posi for trucks with 28 spline axles. would this work in our cars? what do yall think......
Re: another thought for strengthening 10 bolt....
Not to pee on your parade, but why bother with the 10-bolt? No matter how badass your housing or your posi you're still running that wimpy ring gear. These things work(ed) okay behind Monzas and S-10's, but they have no place behind an LS1! Hell, even my ZR2 came with an 8.5" 10-bolt - even that would've been a step in the right direction.
the weak link in the 10-bolt rear end is the tiny gears. They are just too weak to hold any power.
If you're going to beat on the rear end, you WILL put in a beefier rear end.
