Moser 9" problems
At this point its not the U joint, its not the drive shaft, its prolly not the pinion angle... that only leaves the rear.
One thing you might want to check... make sure that the axle tubes are perfectly in line. Moser actually has a certain "tollerence" as to how many degrees they can be off (a problem stemming from the welding of the axle tubes to the center part). That can cause the tires to not be perfectly parallel... You figure the rest out.
Yes Moser says that a certain amount of that is normal and they wont warranty that. Someone needs to sue the hell out of them for selling crappy stuff at premium prices.
From BMR's website
Setting pinion angle:
Support vehicle under rear axle to load the suspension for pinion
angle adjustment. Once suspension is loaded, attach the provided
angle finder on the bottom of the rear end torque arm mounting plate
and record the reading. Now place the angle finder on the driveshaft
and record the reading. Subtract one angle from the other, this is
your pinion angle. This angle is considered negative when the pinion points downward. It is best to start
with 0 degrees pinion angle and adjust accordingly based on the cars launch characteristics and parts
combination. As a rule of thumb, most automatics typically respond best to a -1 to -2 degree pinion
angle while manual equipped cars respond best to a -2 to -3 degree pinion angle.
Sorry to hijack the thread!
From BMR's website
We have found the parking brake shoes to cause squeeking noises when turning in the past ??!!?? Have you removed the rear wheels and looked for any witness marks on the brake hardware?
g
