which 12 bolt moser or strange?
Old Dec 27, 2002 | 02:45 AM
fatboy's Avatar
Default which 12 bolt moser or strange?
thoughts, opinions and past experience would be appreciated
Old Dec 27, 2002 | 07:21 AM
99MONGOOSE's Avatar
Default Re: which 12 bolt moser or strange?
I have a Moser but it wasn't assembled by Moser. Rapid Motorsports had a local guy do the set-up, and its great, very minimal whining. I understand that people who have gotten the Moser assembled are complaining a lot about noise. It seems that Moser has had some difficulty in gear set-up. The Moser also utilizes 4 short single bolts to contain the Torque arm, instead of the 2 really long bolts w/ nuts that the OEM arm/10 bolt use. Most Moser users have had some problems with these four bolts backing out and this causes the torque arm to break. This also happened to me. I now have loctited them in and used lock washers. I hear the strange unit uses the same 2 bolt design as the Moser, but I am not certain. Hopefully a Strange user will chime in here to verify. Both units are good units no doubt and both are about the same price when fairly equipted with options. I have a HD Eaton Posi, 33 spine axles, T/A cover, ABS, and traction control and 4.10 gears. I would recommend you get these options too, the gear choice is personal preferance but if you have an M6 trans go with at least 4.10s, if you aren't using any power adders.
Old Dec 27, 2002 | 02:57 PM
Magic Man's Avatar
I have a Moser with 3.90 gears in my A4 and I like it.A year ago everyone was down on Strange but now some bad mouthing is going Moser's way so take your pick as both are proven pieces.
Old Dec 27, 2002 | 09:55 PM
mike c.'s Avatar
i have the moser and LOVE it. mine is actually quieter then my stock 10bolt. everything bolted togeather nice (not REAR swaybar)i dont have one on and dont miss it. the rear takes one hell of a beating,overall i'm happy with the product.some people are having bad luck with noise and for the money they paid,i think that sucks. goodluck to you and them.
Old Dec 28, 2002 | 01:50 AM
fatboy's Avatar
thanks guys, no one has a strange? post up already
Old Dec 28, 2002 | 02:33 AM
SILVER BULLET's Avatar
Another Moser here. No gear noise w/ 3.73.
Old Dec 28, 2002 | 03:43 AM
Top Fuel's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by mike c.:
<strong> i have the moser and LOVE it. mine is actually quieter then my stock 10bolt. everything bolted togeather nice (not REAR swaybar)i dont have one on and dont miss it. the rear takes one hell of a beating,overall i'm happy with the product.some people are having bad luck with noise and for the money they paid,i think that sucks. goodluck to you and them. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Why don't you have a rear sway bar on? I believe all you have to do is get some 3" ubolt clamps and the swaybar will mount right up to the Moser. There is no advantage whatsoever of not running a rear swaybar.
later,
Steve
Old Dec 28, 2002 | 04:14 AM
Colonel's Avatar
The Moser is the stronger unit. Just don't let Moser set the gears.
Old Dec 28, 2002 | 08:23 AM
WS6Modder's Avatar
Ive got the Strange and have quite a few passes on ET Streets on it. As for Moser being stronger...Im not so sure (far be it from me to disagree with the Colonel). A 9 inch..yeah...definitely stronger. But I have seen no evidence from the 15 or so local guys running 12 bolts that the Moser is stronger.
I have minimal whine..just a little at 60 or 65 at part throttle.
I have heads going on in a few weeks and should put down 430ish...so we'll see how the rear likes that under 1.6ish passes next year.
Old Dec 28, 2002 | 09:02 AM
Slowhawk's Avatar
LS1Tech Sponsor
Strange with 3.73 gears.Couldn't be happier with it.Minimul whining noise at light throttle(only heard when radio is off).I put about 50 passes on it this year with no problems.
Old Dec 28, 2002 | 03:02 PM
WILWAXU's Avatar
For most of us on a street car, it's a apples to apples comparsion. You like green or red ones? Or the one you can get the cheapest?
Find a sponsor with a GP. You can't go wrong with ethier setup.
Old Dec 28, 2002 | 09:20 PM
mike c.'s Avatar
i tried to put the rearsway on with muffler clamps,it did'nt work. i drove with it off and did'nt notice a real difference with it off,so i just never put it back on. i will add it back on sooner or later.
Old Dec 29, 2002 | 12:34 AM
Colonel's Avatar
"Ive got the Strange and have quite a few passes on ET Streets on it. As for Moser being stronger...Im not so sure (far be it from me to disagree with the Colonel). A 9 inch..yeah...definitely stronger. But I have seen no evidence from the 15 or so local guys running 12 bolts that the Moser is stronger."
That's probably because none of them are running fast enough for it to matter (are any of them running at least 8s in the 1/4?) I didn't say the Strange housing (which I believe is a factory GM housing) is weak. I said the Moser housing (which MOSER designed from the ground up to be even stronger than their 9") is stronger.
Having said that, I think either housing is strong enough for just about any of us, myself included. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Dec 29, 2002 | 10:09 AM
Colonel's Avatar
<strong> i tried to put the rearsway on with muffler clamps,it did'nt work. i drove with it off and did'nt notice a real difference with it off,so i just never put it back on. i will add it back on sooner or later. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Spohn makes a kit to do it. It's not that hard to modify the stock ones to work if you have some welding skillz or access to someone who does.
Not having a rear swaybar is really bad for starting line traction.
Old Dec 29, 2002 | 10:21 AM
ShadowZ28's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Colonel:
<strong> The Moser is the stronger unit. Just don't let Moser set the gears. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You can actually order the rear and ask them not to set the gears for you?
Thanks
Joe
Old Dec 29, 2002 | 10:47 AM
FastBlackTA's Avatar
I have a moser w/ 4.10's. Just installed it yesterday at my shop and it looks great. I'll keep you posted on how it performs. Doing a little fabrication today to get the stock sway bar back on! <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
Conrad
Old Dec 29, 2002 | 02:15 PM
fatboy's Avatar
<img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Old Jan 9, 2003 | 01:35 PM
CMNTMXR57's Avatar
What were your issues with installing it? I'd be doing it myself preferably.
Old Jan 9, 2003 | 02:22 PM
Magic Man's Avatar
It's a one for one swap everything bolts to the same spots.Sway arm mounting will need to have a 31/2" muffler clamp as tube sizes are different.Might get a freind to help just to make it easier.
Old Jan 9, 2003 | 02:27 PM
CMNTMXR57's Avatar
Awesome!
When I meant I'd do it myself, I meant in my garage. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> I'd have a friend there. No need to pay someone what you can do yourself.
