rear end ?
Old Oct 17, 2007 | 12:45 AM
staringback05's Avatar
Default rear end ?
ive got a stock rear end with motive 3.73s, new bearings, and mac cover....
its been leaking lately pretty good, it drips from where the cover is flush with the axle...ive gotten a couple opinions and they've all come to the pinion seal, which i can go for also....the gasket between the cover and axle i believe isnt leaking....my question is, i know theres really 5 holes on the rear end where fluid can come out....cover gasket, top fill hole, back fill hole, drain hole, and pinion seal....are there any other areas where it could leak from? ive been filling the rear from the back fill hole to right below the hole....so i dont believe im over filling it
Old Oct 17, 2007 | 07:55 AM
omcar's Avatar
there is a vent hole at the top right..look for a small tube.
