Rear end woes
Last year (Aug to be exact)my stock rearend had the carrier bearings go out.i decided it was time to take advantage and rebuild with 3.73 gears and all new bearings and seals.Everything was fine,i picked up .2-.3 and 1-2 mph in the 1/4.In Jan I installed my Midwest convertor i was very pleased with the setup.In may the gears started whining a bit so i brought it back to the place that installed them and he said the backlash had moved to about 20 thousanths,we came to the conclusion that the gears werent cut exact from the factory(US Gear)and they wore in.He reset the rear and it was back to normal.Less than a month later the bearings went out again,the races and the rollers were flaking apart .so he replaced the bearings again and reset the rear,he said the wear pattern looked good.four days later the rear all of a sudden started sounding like a siren(I couldnt here my exhaust over the whine) So I dropped it back off and he found the backlash at 30 thousanths,he reset it again and said that it wore a grove in it and the noise wont come out He said that the rear is set up with a 2 series carrier with 3 series gears,is this true?He wants to put in a eaton posi unit with a new set of gears.Im kinda leery to do this,should I?Im contemplating the idea of going with the Ford 8.8 setup since I cant afford the 9" or 12 bolt.
I havent been to the track since about March so the rear hasent seen any real abuse ,plus its an A4 so it dosent see as much shock as the M6.Ive been told that the whining will not hurt anything to drive,it will just be loud,im going to take a trip to florida this coming week and was planning on driving the car,should I?
any opinions will be much appreciated.
Think about it, if the compartment that the round race resides in is no longer round but now an oval shape the race has a risk of binding and if your carrier bearings inside the race bind then the race will spin with the bearings essentially honing out the saddles and the housing. It's not worth paying for numerous teardowns if you can stop it here.
For your sake, please just have the installer mic the saddles and carrier race slots in the housings to be sure they aren't out of round.
It seems that the problems started when they reset the gears in May. Actually, if you see any black lines or grooves on the races and/or the saddles then the housing is pretty much toast. You'll be able to put new gears, etc in but you'll keep eating up races, bearings and eventually break the differential. If that breaks you could lock up the rearend which could lock up the driveshaft and boom, tranny is gone
The carrier bearing saddles' should have a nice cross hatch pattern similar to what you would see in a freshly honed cylinder bore.
