Swap time
Old Oct 25, 2007 | 12:14 AM
my number 1 hater's Avatar
Default Swap time
I have an ABS 3 channel rearend on my 98 z ... I will soon be getting a free low mile ABS 4 channel from my buddy... What needs to be done to make this work????
Old Oct 25, 2007 | 11:18 AM
what happens when your rear abs is not working???
Old Oct 25, 2007 | 11:22 AM
mikenews's Avatar
Default 4 channel
Weird my 98 has a 4 channel your has a 3?
Old Oct 25, 2007 | 11:31 AM
Crazy i know!!!!!!! does your car a TCS???
Old Oct 25, 2007 | 05:41 PM
camaroguy26's Avatar
my 98 Z is a 3 channel, no TCS. The 3 channel rear has one sensor in the housing, right above the carrier's teeth. The 4 channel rear has 2 sensors, one on each axle for the traction control. I don't wanna give you false info (I've never done it, just read about it) but to convert the 4 channel to 3 you have to drill a hole in the housing above the carrier (use your old rearend for reference) and install the sensor. As for the axles I'm not sure if you have to swap those out or not but I think you're ok running the 4 channel axles in it. Do a search there's talk about it every now and then. Oh and I'm also not sure if the 4 channel carrier's have the teeth for the sensor like the 3 channel carriers do. I believe they do but don't rely on my word.
Old Oct 25, 2007 | 10:22 PM
Thanks sounds like work i dont want to do ....
Old Oct 26, 2007 | 12:36 AM
Scott@DrivelineSolutions's Avatar
LS1Tech Sponsor
Your 12 bolt can be converted and I have done a few in the past. If you have the time shoot me a PM.
Old Oct 26, 2007 | 12:45 AM
hey man just saw there's a sticky with pictures.
https://ls1tech.com/forums/gears-axles/617761-converting-4-channel-3-w-pics.html
Old Oct 26, 2007 | 10:07 AM
https://ls1tech.com/forums/showthread.php?t=617761
cool thread... nice tooling that dude has... But im not about to do that in my drive.... Whats the big deal with ABS i drove a ton of cars without ABS..So with that in mind, What happens when the rear ABS DOES NOT WORK..Will the front ABS still work ..I am sure the ABS light will come on but i can take care of that....Will it mess the way my car runs???
Old Oct 26, 2007 | 04:32 PM
I believe you can delete the ABS pretty easily. There's more threads about it if you want to search for it. I've never read up on it though.
Old Oct 26, 2007 | 09:28 PM
Razor_Blade's Avatar
abs is nice if you do a lot of emergency braking. Otherwise, you will never know it's not working.
