M6 with 4.30 gears?
To maximize performance, of course you want to choose the gear that allows you to come through the traps as high in your powerband in fourth gear as possible.
For my cammed & sprayed Camaro, 4.11 was the proper ratio selection.
Find your target MPH, go the gear calculator and find out what gear ratio will leave you on redline in 4th at that mph with your tires, and there you have your optimal gear ratio
