Centering Moser 12 bolt.
Old Nov 4, 2007 | 04:45 PM
davisd2's Avatar
Default Centering Moser 12 bolt.
12 bolts in but now both back tires rub on the bump stops. I did a search and read to take it of the jack stands because the rear for some reason leans toward the pass side. Is this what I need to do? The 315-35-17 ZR1`s with 36mm backspacing isnt the problem is it? What do I need to do?
Old Nov 4, 2007 | 05:43 PM
Scott@DrivelineSolutions's Avatar
LS1Tech Sponsor
Did they rub before the install? The axle maybe a little narrower than your 10 bolt was. But once you get it on the ground the rims will clear and also your springs will take some time to settle as well.
Scott @ DLS
