locker question
Old Nov 11, 2007 | 07:40 PM
ramsoccer11's Avatar
Default locker question
ok either im missing a very basic understanding of how a locker works or i got the wrong parts. i had a locker installed(or so i was told) but after all was said and done the rear leaked so i had to take it back apart and re-seal the diff cover. anyway while i had it apart i spun the passenger side wheel and noticed that the drivers side didnt move. my understanding was that both should move if one does...is that wrong?
Old Nov 11, 2007 | 10:25 PM
BuckaroooZ28's Avatar
yes, both should turn
Old Nov 11, 2007 | 11:52 PM
chicane's Avatar
First off... it depends on which differential and which locker you are using.
If the differential is unloaded you may just be able to turn one tire without the other turning. That is not uncommon.
Old Nov 12, 2007 | 06:29 AM
the only thing i was told about the locker was that it was a ratcheting one. but thats good to hear about it being loaded.
now if i can just make it stop howling ill be good lol.
Old Nov 12, 2007 | 10:42 AM
Jays00ss's Avatar
go to Eatons website. They have a user manual in there with an operational check of the Detroit locker. Here ya go http://www.eaton.com/ecm/groups/publ.../ct_128312.pdf
Old Nov 12, 2007 | 05:00 PM
chicane's Avatar
I guess I should have directly asked... are you still running the 7.5" or have you changed the differential as a whole ??
Old Nov 12, 2007 | 07:23 PM
sweet! maybe i should have looked at the instructions
Old Nov 13, 2007 | 12:59 PM
excuse the ignorance, but i really dont know everything there is to know about rear ends. heres what i do know, i gernaded the stock 10 bolt(housing and all) found someone that had an extra housing laying around and put in a ratcheting locker and 4.10s(Richmond) which now wine pretty good.
